kta176
32
I have a 2002 KX250 that just recently started blowing alot of white smoke. I did the top end a week ago put in new rings, piston, and cylinder. I was riding for about 2 1/2 hours with no problem, I took a break and leaned the bike against my truck. When I started up I immediately noticed that the bike was blowing
constant white smoke out of the pipe. I replaced the head gasket to see if coolant was getting in but it's still blowing smoke. Anyone have an idea of what could be wrong?
BLACKeR
76
have you done a leak down test? its possible you warped your head. did you use a torque wrench and the proper procedure when tightening it down?
BLACKeR
76
i ask because a leak down test will show where any leaks in your engine are ahead of time. this way you avoid any costly air leaks and frustrating situations like this. to make a leak down tester you need an expanding rubber plug to plug your exhaust. then you need a rubber plug to plug your reed intake. that rubber plug needs to have a hole in it, so you can glue, or caulk in a valve stem. it must be air tight. then you pressurize the engine to 7 psi to do this i use a mighty vac. it should hold 7 psi for 10-15 min. with little to no drop. if you get a drop in PSI put some soapy water around your gaskets, and boots. where the soap bubbles you have a leak. also note that i edited my original post with another question.
