Originally posted by bscottr
I’m always up for learning alternate methods and would like to find out more in the way of bladder removal and the gains expected by doing so.
Scott,Originally posted by scotth
Did your bike have this setup before you modified it?
When I started down this road I bought the Gold Valve kit, but I never installed it. After reading a bazillion posts I found that a lot of the smart guys found that success can be had with the stock valves. (Like James for example). It seems that it’s all about flow, larger ports in the valves = stiffer base valve stacks, smaller ports = lighter valving. (Wade on in here guys if I go astray). So I elected to try different setups with the stock valves.Originally posted by scotth
did you buy the Gold valve kit or just the mid valve conversion kit?
I have wondered about trying the gold value kit. It sounds like it takes the guess work out of re-valving.
DittoOriginally posted by James
The Gold Valve kit may get you where you need to be but you may need to fiddle with it a time or two (or more). I am pretty much sold on modifying the stock stacks and saving a few hundred dollars.
I’m looking forward to the feedback. I think you’ll find it’s a step in the right direction. I also found that my clickers had a much wider range of noticeable adjustment than that of the stock setup. Maybe I've gotten a little more in tune with my bike as well, but now I can tell when I make one to two click changes. Before it took big changes to notice the difference.Originally posted by scotth
I will try your setup with the 3 24x10 shims this weekend and let you know how it went. Thanks for giving me a good starting point. :thumb:
I am trying the Gold Valve in my 2000 shock for the heck of it. Gotta drill the bleed hole and put it back together. I have been real happy with my home modified shock on the 2002.
We gotta talk. :confused:
When somebody says this to you, it usually isn't good news :thumb:
Originally posted by flynbryan
Us cheap skates need to stick together. ;)
Yup...that's it. :thumb:Originally posted by James
or better yet "inquisitive"
Do you remember if you could feel the effect of removing just one of the 24x10 shims at a time or did you have to remove 2 or 3 to really notice a difference?
I hope it works out for you! If you want to ride with a lot of great folks come on down. Our BS sessions are usually as fun as the riding and we can do some tuning. :thumb:Originally posted by scotth
TNT on Monday is a possibility; I think it is about 3 1/2 hours from Raleigh. :(
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
