BEEF706 said:dsguru, mine's an '02 raather than an '03 but I think the results are probably similar, I have tried a lot of mods looking for more low to mid the most effective were 1. porting and head work, very effective, 2. power now, I couldn't believe this little wing made as much difference as it did, 3. PC pipe and silencer, I dinged mine up and went back to stock, not nearly the difference I had thought it would make. If I were starting with a new one I would probably pop a power now in it first and then send the motor to EG. Of course if you're looking for more top end I am no help at all. :laugh:
BEEF706 said:mos11b, the Power Now is an insert that sits in the throat of the carb, it has a wing horizontally across it. I am not sure of all the physics involved, but I believe the concept is that is smooths the turbulence out of the airflow and speeds it up at lower throttle settings, improving throttle reponse. I can tell you it makes a pretty big difference on my '02 :)
