O'MALLEY_808
10
Hi I own a 2002 Cr125 and had to go through the trouble of re-sealing the airbox. I just bought a 2003 Cr250 and was curious if this new foam gasket has cured the problem or do I need to make some changes.
Let me know if anything needs to be done.
Thanks in advance
NO HAND
1,198
My 03cr250 leaked also. Keep an eye on it. The honda foam ring is a lousy fix because it is porous and lets dirt in. The whole design is flawed because there is not enough screws for such a soft flexing boot. The pressure is not equal on that seal, at some place there is so much distance between the screws I could get a credit card through.
NO HAND
1,198
Hi, no I never been to walton. I race the EOMA serie every year. eastern ontario association, from the cmrc. Got the yellow panels (intermdiate). Have you been to sand del lee MX park?
O'MALLEY_808
10
Naw I havnt had the chance to make it over to that track...im close to toronto so I usually run the south western ontario circuit. I just moved up to intermediate and im adjusting to the new pace pretty quickly. Maybe ill see you around.
_j0kA_
378
odog - get out.. joes ordering the mxbonz aluminum (i think) fix from mxsouth.. i think the neoprene one has to be replaced over time? you should have bought a suzuki
psycho
King Rot-Gut
219
I did the MX-Bonz mod (aluminum) on the airbox and have been pleased with the seal. The factory foam IMHO is junk.
