see picture at
http://www.suzukicycles.com/sr_02/dual/images/bp_drz125.jpg
DR-Z125/L
SPECIFICATIONS
Engine: 124cc, 4-stroke, singler-cylinder, SOHC
2-valve, air-cooled
Bore/Stroke: 57.0 x 48.8mm
Compression Ratio: 9.5:1
Carburetor: Mikuni VM20
Lubrication: Wet sump
Ignition: CDI
Starter: Kick
Transmission: 5-speed constant mesh
Final Drive: Chain
Overall Length: DR-Z125 - 1835mm (72.2 in.),
DR-Z125L - 1885mm (74.2 in.)
Overall Width: DR-Z125 - 880mm (34.6 in.),
DR-Z125L - 885 (34.8 in.)
Overall Height: DR-Z125 - 1055mm (41.5 in.),
DR-Z125L - 1085mm (42.7 in.)
Seat Height: DR-Z125 - 770mm (30.3 in.), DR-Z125L - 800mm (31.5 in.)
Ground Clearance: DR-Z125 - 245mm (9.6 in.),
DR-Z125L - 275mm (10.8 in.)
Wheelbase: DR-Z125 - 1245mm (49.0 in.),
DR-Z125L - 1270mm (50.0 in.)
Dry Weight: N/A
Suspension:
FRONT: Telescopic, oil damped
REAR: Link-type, oil damped
Brakes:
FRONT: DR-Z125 - Single Drum,
DR-Z125L - Single hydraulic disc
REAR: Single drum
Tires:
FRONT: DR-Z125 - 70/100-17,
DR-Z125L - 70/100-19
REAR: DR-Z125 - 90/100-14,
DR-Z125L - 90/100-16
Fuel Tank Capacity: 6.6 liter (1.7 gal.)
Color: Yellow
Print Window
