2003 RM250 compression:
jackdrinker
431
I'm getting ready to sell my bike and the following gremlins developed..
Bike will not rev.. It will idle and rev when blipped..
It takes allot of kicks to start it when it used to only take 2-3
It makes a poof kind of backfire
looks like raw un-burnt fuel coming out of the powervalve breather.
Plug gets really wet..
bike sounds like it is totally loaded up and when you ride it, spudders all over it's self.. If you goose t and short shift to about third it will run, but will not rev out..
I took the stator cover off and found some corrison on the flywheel and clutch arm.
I drained the trans oil and found about 2/10th of what I put in earlier this season.
I'm going to do a compression check before I say it's a crank seal.
Any one have the minimum and maximum numbers for compression and any advise?
Thanks,
Jonathan
ETS
82
The old rule of thumb I used was anything over a 100psi should run good. Does it take numerous kicks to start? Thats a good sign of a low compression also.
jackdrinker
431
filters clean and plug keeps getting wet... Replace it and the same thing...
I'm doing a compression check later but I need to know the minimum and maximum...
nectar
175
If only 20% of trans oil was left than I think you have a crank seal problem which would result in fouled plugs, alot of blue smoke and real rich running condition.
wornknobby
625
if numerous kicks could equal low compression than why can i start my bike with one kick when i only have 85 lbs of compression?
jackdrinker
431
Wow!!!. that was a useful post...... most likely because your 88' kx125 is not a 2003 rm250.... bhaaaa
anyhow,
needs rings... i got 125 throttle closed and 130 throttle open..
pulled the jusg and yup, needs rings...
ordered all the parts today...
thanks,
if anyone has those numbers that i need let me know..
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
