jasonboche
- Apr 3, 2002
- 10
- 0
stroker said:is the carburation any better on the 2004 then the 2003 CR250 was? I actually liked my 2003 alot, except for the picky jetting... also heard the Boyesun Rad valve with a pro circuit 2 pipe helps the bottom power on the CR's.
If that is indeed actually happening, you would think that one of the aftermarket programmable ignitions would be an easy fix. On my 2003 CR250, once I installed a Keihin PWK carb it was a completely different bike, very responsive, lots of power everywhere. It even sounded different! The 2004 model has a TPS equipped Mikuni, so you can't just swap to a Keihin anymore, but I have yet to talk to an owner to see if the 2004 carbureates any better then a stock 2003 did.Micahdawg said:I thought a lot of the problems with the 03 and 04 CR250's were the glitchy electronic power valve? Seemed like most of the reviews I've read attributed the inconsistent power delivery to the electronics...mostly due to wrong maps being referenced for power valve actuation (or getting hung up between maps).
Micah
Do it! If I had the opportunity to buy a motocross bike again it would be the Honda CRF450 hands down.I'm triying to deal my 04-yz-250 for one but the dealer's around here are telling me two strokes on their showroom floors are not selling at all.Just wish I'd known what I know now. Good Luck with what ever you purchase.jasonboche said:I'm 75% convinced to cancel my order of the '04 CR250 and grab their last remaining '04 CRF450 that's sitting on the floor.
motometal said:CR69r, regardless of what the official "spec" is for compression, I would highly recommend running at least a partial mix of race fuel on the CR250, assuming you want to jet it to provide any kind of decent throttle response. With stock, blubbery jetting, is 91 octane ok? Probably. My '01 and '03 both are on the verge of pinging when running premium pump fuel.
Race fuel sure helps with the peace of mind...
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
