2005 CRF276 Ice Cube Cam question
jr.ink
15
Can Someone please tell me what cam is going to give this configuration more top end? I love the torque but need a little more on top for hole shots and long straights.
Oh yeah...WB carbon pipe, run pump 91 octane,rejetted already etc.
Vet and Plus 25 A MX rider.
Thanks to everyone for the help!
:cool:
Jeremie91
hot125mod
501
here are the specs for the stage 2 cam which should be just what you want intake lift 8.4mm intake lobe center (degrees) 107.5 intake duration 252mm valve lash .12 now for the exhaust lift 8.35 lobe dia 102.5 ex duration 267 lash .28 compare that to the stock or stage 1 and you will see the difference. or ask eric gorr good luck
