2007 Kawasaki KLX250 starting problems
Do you turn the fuel off when the bike is sitting? You may have a float adjustment issue. With other 4 strokes, some need a small burst of fuel before your try to start. My YZ450 need 2 quick stabs of throttle then kick with no throttle added. Started first kick. Experiment a bit but I suspect the float needs adjustment or the needle valve/seat cleaned.
FRESH VIDEO
