AJ Waggoner
Crash Test Dummy
Nov 5, 1999
4,368
34
2014 Service Honda CR500AF
MXSparx
Mr. Meltsomeglass
Jul 25, 1999
3,724
71
NoVa
Beautiful as usual. :cool: :aj:
Does it feel, handle or fly different than the last couple years? (not that there was anything wrong)
We need SPECS AJ !
Vic
***** freak.
4,008
:cool:
AJ Waggoner
Crash Test Dummy
Nov 5, 1999
4,368
34
AJ Waggoner
Crash Test Dummy
Nov 5, 1999
4,368
34
AJ Waggoner
Rich Rohrich said:
We need SPECS AJ !
Based on the 2014 CRF250R
(no air forks, a good thing in my opinion)
Specifications:
Engine Type - 500cc liquid-cooled single-cylinder two-stroke
Bore And Stroke 89mm x 79mm
Induction: Eight petal reed
Ignition: Breathtaking, and smells like victory!
Compression Ratio 6.8:1
Valve Train: You're kidding right?
DRIVE TRAIN
Transmission Close-ratio five-speed
Final Drive #520 Chain; 14T/49T
CHASSIS / SUSPENSION / BRAKES
Front Suspension 48mm inverted Showa cartridge fork with 16-position rebound and 16-position compression damping adjustability; 12.2 inches travel
Rear Suspension Pro-Link® Showa single shock with spring preload, 17-position rebound damping adjustability, and compression-damping adjustment separated into low-speed (13 positions) and high-speed (3.5 turns); 12.3 inches travel
Front Brake Single 240mm disc with twin-piston caliper
Rear Brake Single 240mm disc
Front Tire Dunlop MX51FA 80/100-21
Rear Tire Dunlop MX51 100/90-19
DIMENSIONS
Rake 27° 23' (Caster Angle)
Trail 118mm (4.6 inches)
Wheelbase 58.6 inches
Seat Height 37.4 inches
Curb Weight 231 pounds (Includes all standard equipment, required fluids and a full tank of fuel–ready to ride)
Fuel Capacity 1.66 gallons
Ground Clearance 12.7 inches
OTHER
Available Colors Red, White , Black
Model Id : Service Honda 500AF
Thanks AJ, another masterpiece from your shop.
Wardy - You've seen me ride. I'm clearly going with my strengths on this one. ;)
Is that one your's, Wardy?
