crdude97
5
Just wondering if anyone has any suggestions for my 2000 300mxc. I just switched to a #7 slide,175main,45pilot,nozi needle 3rd from top,as1.5, and 2 t/o idle. Bike starts fine,runs great on top, but seems to sputter from 1/4 to 1/2 throttle,lots of spooge,but no fouling.This is at 300ft,40:1 mobil 1 94 oct. Should i try to move the needle clip up first or go ahead and change the main and pilot smaller? I would like to try and get it right with the stock needle if thats possible. Thanks for any help!!!:think
fremontguy
580
Those nozi needles run pretty fat. I would take the needle clip up one step at a time for the 1/4 to 1/2 throttle sputter, spooge problem.
RBW
28
There is a company that makes a jetting kit that works killer for the GasGas's.
It totally cleans up your jetting issues. They claim it also works well on the KTM's.E-mail me for the specifics if your interested.
Strick
1,782
It's a needle issue. Single Tapers are they way to go on KTMs.
RBW - what needles does the kit come with? How much is the kit. Needles are $5 each from sudco, jets are $3.50 each.
Tennessee Thumper
446
They told me the KTM kit comes with the #7 slide and a few jets and single taper needles.I think the "kit" is $120.:eek:
Greg
17
My jetting suggestions for what they're worth on my 2001 300 mxc. Gas...50% race gas/50% pump 93 octane mixed 50/1 with belray H1R...170 main, 42 pilot, #7 slide, NOZI needle clip in top position. Altitude 500 to 700'. Air screw 1.5 depending on temp. Bikes runs clean everywhere. After a 2 hour harescramble will have just a little bit of oil dribble out the silencer. I am a lugger in the woods. In wide open riding staying on the pipe, have no oil out the silencer. I am running the stock MXC 300 silencer.
RBW
28
Strick,
the kit is around $30 and the needle number is a secret.The numbers are ground off.I guess you're paying for the guys knowledge as well as the parts themselves.This kit works flawless on my GasGas,well worth the money.
Strick
1,782
Thanks RBW, Digital calipers and one can decipher. We have the Technology!! I'll bet a lunch that it is a single taper needle!
Matthew
22
I am running a #7 slide
DEJ needle in 2nd
45 pilot
178 main
Runs real good I might try dropping the pilot to a 42 but it doesn't load up and I have done ome trail riding with the wife and boy with it and it seems ok with that.
Matt
00 300exc
JohnScott
96
I have also heard that many of the jetting problems with the 300 MXC are with the NOZ series of needles. I tried to find a CEK needle but they're on "national backorder". I went with a CEJ needle (single taper) in the third clip with a 42 pilot and 178 main. I'm running the stock 6.5 slide. I'm still getting a little bit of rough running from 1/8 to 1/4 throttle so I'm not totally done - no spooge. I couldn't keep a plug in it until I got rid of the stock needle.
