- Nov 19, 2002
- 645
- 0
Ok here it goes... My friend's 2002 XR100 is bogging from about 3/4 throttle to full throttle in any gear, including neutral. My 2000 XR 100 never did this when I had it a few years ago. And on the spark plug, there is carbon. (dry black stuff) Usually if you clean the plug and put it back in or if oyu put in a new plug, it will run fine for a little while, but it will happen again, with the plug. The black stuff is not spoogy, it is dry. What could be the problem? i think it might be running with too much air, an dnot enough gas. I believe this is called lean. What would be a fix to the problem? Thanx for the help!
