ray r
6
i have a 41 mm mikuni carb that runs extremly rich to the point it stops running also fuel economy is terrible i have tried almost everything i can .smallest pilot. leanest needle .leanest slide only thing i have not tried is the needle jet would this be the problem .
Jeff Gilbert
2,969
The air screw effects between idle and 1/8 throttle
Pilot jet is between 1/8 & 1/4 throttle
Slide valve is from 1/8 through 1/2 throttle
Needle jet from 1/4 through 3/4 throttle
Main jet is 3/4 to wide open
