My buddy just got his '00 426 put back together after completely rebuilding the bottom and top end. But, he's not getting any spark. This is what has happened and what he's done:
Original problem: A shim came loose in the bottom end and the engine basically ground it up. The metal cycled through his oil pump, tore up the cylinder walls and piston, and chewed up a couple of the gears in the bottom end. After the local Honda dealer replaced ALL of the parts in the bottom and top end (all gears, cylinder, piston, valves...everything but the cases) they refused to repair the engine (the whole mishap was their fault....but thats another story). So, my friend, with the aide of his repair manual got the engine completely reassembled (after washing EVERYTHING in his parts washer) and put back in the bike.
He never removed any of the electrical connections attached to the bike, so these should be in order. He's disconnected the kill switch to rule out that as a potential problem. And he's put a new spark plug in. The only thing we can think of that may be a possible problem: when he removed the stator, there was A LOT of ground up metal and metal chunks in the stator housing. He washed all of this out in his parts washer and nothing appeared to be damaged. Could the solvent have affected the stator in some way?
We're lost as to what else may be the problem. Like I said, everything was in working order when the engine was pulled (approx. 3 months ago). What are we missing?
