in three weeks, i'm going out to colorado for a week of riding. i don't know the exact location of where we are riding, but it is outside of colorado springs. i believe the elevation is around 7-9k.
current settings
ocemn #4
main 165 (alittle on the rich side)
stock pilot
1.5 turns
stock muff
the areas were i normally ride are only about 400 ft in elevation. from what information i have gathered, i should probably only need to lean my main by about 5-8 numbers. hopefully someone who rides in that area can confirm this.
on a side note, i currently have a bad backfiring problem after chopping the throttle. i have adjust the screw all the way from 3/4 to 2 turns and inbetween. i have gone from clip #3 to #7 one step at a time. none of this affected the backfire at all. i have also tried to seal all of the joints with high temp rtv. nothing seems to help. i am going to try leaning the main jet down to 160, but theoretically this should not help, correct? should i also try clip #2? hell, i don't. i'm about ready to give up and not worry about it. the thing is, my buddy has a 400 with ocemn, and it doesn't backfire at all and he doesn't seal his exhaust joints.
later
marc
current settings
ocemn #4
stock pilot
1.5 turns
stock muff
later
marc
