I have the clutch removed (disengaging the transmission and kickstarter from the process) and have the valve train cover and stator cover open (everything seems ok with the cam, auto compression and other stuff inside those).
I can rotate the crank by hand from either the crank end on the clutch side or the stator between about the TDC before the exhaust stroke and the TDC after the exhaust stroke.
At both ends of that, the crank just stops dead as if I had the stopper bolt (that is used in the valve adjustment procedure) screwed in. However, I have that bolt as well as the spark plug (in good shape) completely removed.
I'm going to remove the flywheel/stator/whatever the thing is at the end of the crank and see if a better look at the cam chain will provide more ideas before the cases come apart.
Any ideas about what might be wrong?
What happened before this problem:
I get to the track and let the bike idle for about a minute. I adjust the idle a bit higher. After I ride about 10 minutes I notice the idle has crept up. Thinking this is because of the bike getting warmed up, I get to the pits and pull in the clutch. The revs rise to what would normally be about 1/4 throttle at neutral (pretty high revs). I hit the kill switch, adjust the idle and try and start the bike. The kickstart lever stops when I try to kick the bike over, probably at TDC. I take the bike home and start working on it, not yet finding the problem.
I have never had the engine this far open, but I do understand how it works.
Thanks in advance for any possible help.
