hbrazuna
12
Is it possible to put a 6 speed gearbox in Cr 125 2001 ? I think so.
Can you please give me guidance on this issue ?
TYhanks alot.
viking20
428
I believe the cases are identical.The cr got a 5 speed box in -98,when the alu frame was introduced,I believe.It will be a big job,Im sure as you will probably need a complete gearbox.The kart people still use the 6-speed ,when they build a new cr engine,maybe a kart shop would be the best place to buy the parts.........Why would you do this?
hbrazuna
12
A Pro told me that increasing a gear the CR will run more strong and the gap will be reduced. He also told me to wait that probably will be possible to bring a new gearbox from one CR prepared by an official team, but I am curious how they do that job...
I hope this makes sense.
NO HAND
1,198
You will need to buy... not only all the gears, but also the shift drum. This would be an expensive mod. The only problem with the 5 gear transmission is that Honda tried to space up the gears to keep almost the same top speed. Try a 53 t sprocket at the back instead. Alot of people on CRs at the track make the switch to a 53 and are happy with the transmission.
viking20
428
Most riders I know of like 1 tooth more on the rear sprocket,if they are not very light.My son is a very light rider and we usually run a 51 on a dry hard track......If you want to build a 6-speed cr,I guess it would be easier by far if you use an older engine in your frame......
