Hello all,
Hopefully someone with mass carnal knowledge of kawasaki can help me out with this problem. We got a sweet deal on a "89" kx 125 in good shape, compression was a litle low so we had a sleeve job done to the cylinder but the compression is still low(85psi) I checked the reeds and they are good, it don't smoke like if the crank seals are bad just usual 2 stroke smoke, no head gasket leak's, ring end gap is .018 the machine shop said that was ok. I took it back off had them check it for egg shape and it was ok. I timed the exhaust valve's and they were still in time when I took it apart. Is there something I'm missing, or could there be another problem. Thanx for any help from anyone.
