I noticed, I lost alot of throttle response gradually.I said before using the 927 I didn't have any issues with how dirty it ran well I took off my silencer last night the packing was black inside out from end to end.The ends where the stinger goes and the cap at the other end had alot of carbon built up I am talking alot.The holes in the baffle were clogged pretty bad not in the center ,but at both ends.I got a thin allen wrench and started clearing them out, it was so hard I had to spray easy off to loosen the carbon up.I did alot of scraping at the silencer cap to get the carbon out and the stinger too.Finally I got every hole cleared in the baffle and repacked it.I bet you my throttle response returns.I am not bashing the 927,I know it lubricates excellent ,but now I do see issues with how dirty it does run.For you other guy's who mentioned this before, I see your point.My power valves are working smoothly,but like I said before the main flap has hard carbon around it, even though it opens fully,the carbon around it probally changes the way the exhaust timing operates when the flap snaps open.Now to pick another oil. Do any of you guy's have rust issues using the mx2t,I have done some reading,and from what i understand .Synthetics are excellent,but If the chemical make up isn't good it is not a good rust prevention.
