dirt track killa
- Jun 6, 2006
- 29
- 0
last month I took apart my sons ds 80 to check all of the clearances,and to see if it needed new rings and piston.Well everything mic'd out ok so I put it all back together,minus the oil injection system,I plugged the venturi on the carb that let the oil in and capped the lines to the oil pump.
SO I have it all back together and fire her up,she fires right up,no probs there,so I take off down the block,shes running great thru all throttle ranges.
When I get to the end of my alley and turn around it died,so I fire her back and go back to my house.As soon as I pull the clutch and stop she just wants to die.It has compression,spark,and fuel.
I pulled the pipe apart and cleaned it out,took off the carb and cleaned it.
Could anyone give me some insight on how to keep it running while in gear?
