kyle_3600
25
i was just out riding my kx80. i was 6th gear down a straight and i was braking to go into a turn and the bike just stopped running and never started again? does anyone know whats wrong the plug isnt fouled and i dont know what it could be please help.
dirt bike dave
5,349
Could be it seized up briefly, than un-seized when it cooled down.
Your summer carb jetting might be too lean for cooler temps.
You generate a lot of heat with long pull in top gear. Rolling off the throttle without pulling the clutch in means the very hot motor gets deprived of cooling fuel and lubricating oil, while you are still turning high rpm.
During that brief time your hot motor was turning lots of rpm without fuel and oil, any number of bad things could have happened. Hopefully it is just top end related and the bottom end is OK.
