RECENT POSTS
98 rm125 carb rebuild kit???
Does anyone know where i can find a carb rebuild kit for a 1998 RM125, its a Keihin Carb if that makes a difference. I've looked every where I can think of and still no luck...
There isn't really much to replace in the carb. I can think of the needle valve and seat as well as the bowl gasket. It's not really worth putting a kit together when there are only 3 parts.
well, a friend of mine who knows bikes said that i should get a rebuild kit because my choke doesnt stay up and the idle screw doesnt work, and a couple other little things, but it looks like that bikebandit will have the stuff, thanks so much ,that site is amazingg
No kit, but the choke valve (starter valve in the diagram) is $40. You can get these parts through your local dealer. Idle screws and pilot screws don't usually come with carb kits and don't really wear out. Your jetting is probably off which is why the bike doesn't respond to the idle screw. A jetting kit might help you there, but it's not a carb rebuild kit.
