Eric G. recommened that I put a '99 jug on my '94 CR 250 as he said it has better porting/exchanges etc. They have different part #'s and I could not get a response back from EG to see if that was correct. Where could I figure this out? :coocoo:
Eric recommended that I put a new 99 CR cylinder on my 94 for better porting etc. Do I need a 99 head? I know there are two pistons and two cylinders for that year....
All you need to worry about matching is the head and the piston. The '94 head uses a domed piston, while the '99 head uses a flat top. Either head will bolt onto a '99 cylinder.
