I am in the process of rebuilding the clutch on my 99' RM250 I have replaced the badley worn clutch basket with a wiesco unit and have ordered new fiber plates since the ears of the old plates were worn a lot also. I installed the new basket and oem inner hub and tightend it down. The clutch basket has a little wobbel to it on the shaft but the inner hub is solid. Is this normal or do I need to change the bearing and insert on the driven shaft?
