steve.emma
- Oct 21, 2002
- 285
- 0
hi all,
had an idea the other day about making adding a external mixture adjuster to the main jet circuit on my bikes carb.
i dont know if this has been tried before or not (probably has..)
but anyway here goes.... my bike has a mikuni TM carb,and at the bottom of the fuel bowl is a 17mm hex nut plug that can be unscrewed to gain access to the main jet. my idea works like this....what if i drilled and tapped the hex plug to allow a fuel mixture screw (like out of the idle circuit etc..) to come up through the plug vertically so that as its screwed in it gradually shuts of fuel flow to the main jet. i would need to use a much larger main than normal, but this screw should give you infinite adjustment to lean the main circuit mixture out as the screw is turned in.
the advantge of this (if it would even work) is that the main system could be adjusted to a much finer extent than with changing jets,and you could do it just by turning a screw instead of having to muck around with removing the drain plug and having to twist the carb around in the intake boot etc..
i know there would be some problems such as preventing fuel leakage past the adjuster screw threads, and how thick the alloy plug is to actually drill and tap it anyway. also the screw would have to be just the right sort of length and taper (maybe out of a car carb?) but i think all of these problems could be sorted out fairly easily.
what do you think? anyone have an opinion on this?
steve.
steve.
