i have a couple of questions. i have a 95 cr 250r. i looked everywhere and no oil is leaking. i need the front suspension to be harder. on the bottom of the forks it has a nut you can turn that says S--H and same with the top of the shocks. which ones do i adjust first? also on the top of the shock the is a little brass screw, some one told me to take it out it releases the air from the shock... any info would be great thanks
