i use pj1 filter oil now and it works well but the no toil seems like its easyer to use. my question is wether or not the switch of oils will change my jetting by richning it? . now i spray the filter w/ the pj1 then as if im going to throw it i fling it down so all the access oil comes off then i wipe it off w/ a paper towl. it works well and uses little oil. is the no toil spray on like the pj1? also how well does the pj1 filter cleaner work? when using the pj1 cleaner do u just spray it on n let it dry? or do u wash it off w/ water after? thanks
