am i hurting my suspention?
2FAST4U
13
hey guys,i am 6'1 and about 265,and ride a 1996 kx500.the bike handles really good to me,but im worried that my forks and rear shock are too soft.im just now getting into some small jumping,i jumped this jump i made in my back yard,its about 2 feet tall,and i jumped it at very low speed just enough to get my tires in the air,and i landed.the landing felt good,but im scared im hurting my forks.i looked at them,and i could see the wear mark (left fork is leaking) and it was about 2 or 3 inches from the very bottom of the fork.also,if im bottoming out jumping 2 or 3 feet small jumps,am i hurting anything?thanks.
MACE
Lifetime Sponsor
Nov 13, 1999
441
Please describe this "wear mark". If you mean the dirt line wiped clean by the dust shield, that is normal. At the other extreme, if you have flaking chrome, you in a heapa trubble. Try the film trick mentioned several times this week. You probably will still see some leakage on your '96. If you keep your oil level set properly you can put up with a weeping for a while. If it's on the brake side you run the risk of ruining your pads when it finally gushes.
As for bottoming, I don't think you will damage anything unless you are hitting so hard it hurts. Keep an eye on the rubber bumper at the bottom of the shock shaft. If it starts to crumble you are def hitting it too hard and will have to beef up the 'spension.
JPIVEY
Sponsoring Member<br>Club Moderator
Mar 9, 2001
3,180
Remove that T in you suspention and you should be ok
never ride faster than an angel can fly
2FAST4U
13
As For JPIVEY,dont reply with stupid **** like that,i expect an answer not that bs.as for mace,the chrome is no wearing off,the wear mark i am talking about is a slight fork oil film on the left fork (the fork that has a leaky seal)im not bottom so hard to where it hurts,im not even sure im bottom,but i know im about 2 to 3 inches,give or take a few from the very bottom of the inverted fork tube.
JPIVEY
Mar 9, 2001
3,180
2FAST4U, I sincerely apologize for my stupid
post, I too come here for answers to many questions and would like serious comments
I'm gonna go sit in the corner now
zsr
90
Hey 2fast4u lighten up.
Put a zip tie or piece of thread around the fork leg and go ride the most demaning part of the track. Then if the tie is half an inch from bottom you are about there.
HOWEVER, before you do this check the sag on your shock. This will have a massive effect on the way your forks behave. Always start at the back with the sag
98 CR125 01 CR250 99YZF R1
Thanks to: Motorex / D.I.D. / Vesrah / YES Helmets
Log-In
