Junior had a bad experience through some HiSpeed, Deep , Non uniform whoops. I was close to see it and he doubled in and when the front hit the next whoop the back swapped or kicked causing the front to slam lock to lock then it got ugly....
Junior was just beat up but I feel bad as I am setup man.
Bike is a new 03 TM125E with Ohlins front and back. Bike was broken in with 4-5 hours of race pace trail riding. Bike has WER steering dampener at 3/4 stiff setting.
I checked sag and set suspension per factory suggestions.
During race here is settings. Terrian fast pace AVG 21mph dry,rocks roots
Front
Free sag 50mm : Race sag 63mm
Rebound 12 clicks out from full slow
Compress 16 clicks out from full hard
Rear
Free sag 40mm ; Race 95mm
Rebound 18 clicks from full slow
Compress 16 clicks from full hard
Bike was poor on choppy turns and whoops that are uneven.
Spoke to MXTech and they suggested that the rear may be packing as swapping occurs... I read forums and figured it was possible.
I reset this way and did the testing as close as we could duplicate race course.
14-18mph sections moist not wet soil/ rocks roots
Front static sag 35mm (spec 30 +/-5) Race 50mm (spec 50 +/-5)
Rebound 12
Compress 13
Rear Static 40mm Race 100mm (spec 35 +/-5 / 95 - 105)
Rebound 26
Compress 14
Junior said it is scarey this way, front skated and the back kicked over every rock. Acceleration was not smooth. Bottomed at speed. Front twitchy.
During the testing I tweeked and Tweeked. Over the same stuff.
I ended up with the same sag frt/rear.
Front Rebound 10 from full hard (slower than before)
Compress 9 from full hard (firmer than before)
Rear Rebound 14 from full slow (slower than originally)
Compress 10 from full hard (firmer than originally)
He feels confident this way. I hope JC from MXTech will have time this weekend to check the suspension out as we are running a GNCC.
I welcome comments from any of you guys that have gone through this.
We had our RM85/100 done by MXTech and I have not turned a clicker since I put them on and Junior can slam anything with sure confidence. I hear the Ohlins are great suspenders and would like to get them to work without major surgery :scream:
Front
Rear
Rebound 12
Compress 13
Rebound 26
Compress 14
