attn. TM owners, re: parts
Let's try to compile a list of aftermarket companies that make parts for the TM.. And any parts that fit off of other brands.
Fastway makes footpegs
Emig Racing makes triple clamps
Braking makes brake pads
front fenders from YZs
rear fenders from '94 - 98 KX
seats fit from '94 - 98 KX
250/400 thumpers: YZ426 oil filters
250/400 thumpers: Magura hydraulic clutch, so KTM parts should fit
250/400 thumpers: Arrow makes a titanium exhaust system
Pls. add to the list what you can..
Magura clutch: The Magura MC should not only fit, it definetly fits! And not only on the thumpers but on all TM models. At least over here these parts are cheaper when bought directly from Magura instad from KTM.
Honda CR250R clutch friction plates are used in the 250/300 twostroke TMs. The Honda steel plates work in emergency but rattle terribly.
Honda CR250R air filters fit in the 250/300 twostroke TMs.
Honda CR250R -'96 pipes can be easily adapted for the 250/300 twostroke TMs (just saw and file some material away in the area of the headpipe). GasGas Messico pipes fit on TMs.
Throttle and throttle cable from KTM are identcal.
GasGas uses the same front sprockets (2T at least).
Henk
250 2s
E line make a pipe gaurd that fits
Devol radiator gaurds off a KTM fit.
Re: the air filters, what years CR models fit?
Apparently the 250/400 thumpers use the same air filter, just mounted upside down.
euro gasgas
Wow! ??? Does this also mean that a '96 CR250R pipe can be modified to fit on a gasgas?
thanks,
jeff
- a d v e r t i s e m e n t -
Michelle
Just about any year from 89 onwards. No Toil have labelled them for KTM 360's too (useful for Henk as he's got half a dozen or so from his 360).
Originally posted by euro gasgas
[Wow! ??? Does this also mean that a '96 CR250R pipe can be modified to fit on a gasgas?[/B]
I haven't tried it but I'm quite sure it would work.
MikeS
Lifetime Sponsor
Just want to move this up while adding a couple items.
97TM125E
Air Filter 94-94 CR250,90-97 KTM 250,360
Frt fork Guards, UFO fitting 94-97 KTM 125,250,360 (slight mod need to top)
Brake lever KTM
Rear Brakes KTM 98-99
98-99 Kick starter (top lever only,small mod) gives faster kick for height impaired :)
94-96 CR125 pipe with mod to inlet from old pipe.
Devol skid plate and side guards for Cr125 or 250 pre 97 frames.
Seat cover from 98-99 ktm gripper style works with a trim.
Foot pegs IMS fro 96CR250. 1/2" taller (raises peg slightly for shorter guys)
95% engine bearings are standard bearing house stock. As well as other bearings on bike.
Rebel Gears for Sprockets (fronts are limited) Rear any size/style.
FYI Eric Gorr 150 kit...killer set up. straight line out accelerates many of the best :) been there and done that every Sunday.
Hey Cam,
Can you or anyone confirm that TM 4stroke Air Filter fit with a CR?
My sources tell me otherwise. But I agree they look identical?
My issue is I want to get a cover to wash the airbox out and need a matchup confirmation before ordering one. :aj:
I was told this by my TM distributor. Apparently it uses the same air filter as the 2-smokes, but you just turn it upside down to fit.
Let me know if this is in correct, and I'll pass it along..
Cam
MikeS
Lifetime Sponsor
Moose makes skid plates for 00-02 TM200-300 per catalog
Spoke to Moto Tassinari the tech people said a Delta II from CR125 or a Husky 125 (1997-99) will work great with a slight bit of grinding. If you send them an old stock cage they will machine one to work at no extra charge. This fits the earlier TM125 models : 1997 style motor.
@ chasejj:
You are right. I have got an Airbox Cover from RAMIREZ for a CR250R that fits great for my TM250. So when the for- and trwostroke TMs really use the same filter...
Michelle
For a 2002 TM250MX, a KX250 94-98 seat cover would work? The 2002 seat covers are crap & it's pointless just replacing it with another stocker as it'll still make the bike look ratty, so just wanted to confirm it with anyone who would know.
Cheers
Michelle
