yzf830
I just got this bike for christmas i rode it at track before we did we checked the vavles because it wasnt starting rite. We rode it one the track everytime i went down to first gear it would back fire. No other 4 stroke there sounded like it was back firing. Also it was leaking gas. Can any one tell me wuts wrong with it
oldguy
Always Broken
Where is the gas leaking from?
I am assuming since you do not say that the valves were within tolerances.
The backfiring may mean a lean condition and can be checked by backing the fuel screw out a 1/4 to 1/2 turn. Also is your air filter clean? These are the easiest and more common causes
Spokes574
171
If bike is backfiring on long straight a ways with the throttle wide open, it generally means the pilot jet is lean. I am assuming its cold where you are at, so going up 1 size in pilot jet could solve your problem. I get backfiring in cold weather <55C and I just go up 1 size in pilot and that solves the problem.
Spokes574
