Synthetics are not bad for clutches if they are used from the begining and will work fine in your YZF. Older clutches that have been run on standard oil can often times start slipping if you switch to synthetic.
There is no "BEST OIL" but if you do a quick search in the forums you'll find lots of info on people's experiences with the various oils on the market.
