bogging issues
2004 Cr125 compression is good. New V-force reeds... starts up and runs then fouls plugs all the time... any ideas?
if you check the stickied thread about jetting theres some plug reading links there, right now yer leaving too lil info to help you, how does the machine react in diffrent situations? how does the plugs look ?, what jets are you running?, what needle ?, how many turn on the airscrew. so far it can be alot of things you have to rule em out 1 by 1
good luck mate
did you follow the instructions on the reed package??- your suppose to jet down- a couple sizes most of the time
you should really invest in a repair manual mate =)
cant tell for sure where its located on your bike but its usually a pretty tiny brass screw towards the intake part on the gas inlet pipe side of the carb
good luck
Fouls plugs all of the time when everything else is good is a right side crankcase seal problem.
