Ask for 608 bearings, double sealed. You can use replacement bearings for skateboard/rollerblade wheels; cheap but not double-sealed and would need replacing sooner. Double sealed will be about $5 apiece and the brake pedal takes two bearings.
Both the brake peddle and chain rollers take roller blade bearings. You can get double sealed roller blade bearings or just use the cheap ones without the seals and you can clean them.....
