hello ive noticed on my yz 100 that the very back clutch plate gets broken. this also has happened on my rm 250. i was wondering if that is normal. if not what is causing it.
i think i found the answer to my own problem. are the plates breaking becuase of the grooving on the clutch fingers??? do i need to get a new basket. if so whats a good kind . should i stick to OEM? also should i replace the broken clutch plate??
