All,
On a single cam engine how do set the cam shaft? I understand that the mark on cam needs to point to TDC mark on the head but doesn't the cam have more than one resolution per rev of the crank. Right now the cam is sitting 180 degrees off so if I just rotate it 180 degrees will the valves be in the correct position?
:ohmy:
:ohmy:
