Hi! I was wondering if a D.I.D 520 VM X-Ring c-clip link would fit on my D.I.D ERV2 X-Ring chain? I don't have a rivet tool so id rather not waste money on having a shop rivet it, plus servicing it later would be easier. :laugh:
The specs on the two links are nearly identical (pin length,roller dia.,plate thickness).
Only difference is a very slight bit of weight variance between the two links, which tells me there may be a slight pin diameter conflict.
If the pin fits nicely into the bushing you will be good to go.
Yes, rivet links are a pain...and wayyy overrated.
