B
biglou
Here is the situation: I have a brand new 2002 F150 with the stock radio/CD player. I want to add a set of tweets that I have just to brighten up the sound a bit. I mounted them last night and when I got the first one tapped into the wiring harness, I thought I'd turn things on just to make sure I got the right wires. Well, the wires were correct, but above about 1/4-1/3 volume, the bass was overdriving the tweet making it pop and buzz. I could eliminate the problem by turning the bass down below 1/3, but of course, it sounds like crap like that. I do have caps inline to act as a crossover. I thought perhaps the polarity was wrong, so I switched the leads at the tweeter but it had no effect. I'm not sure what the value of the caps are that are installed right now. That may be the problem right there. I'm just looking to see if anyone has done a mod similar or exactly like this and might have an answer for me.
For the record, they are (were) tapped into the stock front speaker wiring in parallel.
Anyone have any ideas on this? Could the capacitors be too low powered to handle what the stock Ford system is putting out? That seems unlikely to me. Should I get a heavy-duty cap for a crossover or buy an actual crossover setup? I think the latter might be a waste of money since I only need to filter the tweets. Is there some sort of noise filter that could be used, or am I missing something obvious that is right in front of me?
Thanks in advance for any help.
