I noticed the lower drain on the carb seems to be pissing. Sometimes when sitting at idle its a good stream, other times just after I blip the throttle. I removed the carb and believe I should adjust the tang (tab on float). Its definetly not an exact science, seems very difficult to get an accurate float height when trying to determine when the needle touches the tang. In general, should I adjust the tang up or down for the pissing I have described?
03 KDX220
03 KDX220
