castrol premix?
i did a search and didnt really find anything. i bought a 01 kdx220 and the guy said he used castrol premix from walmart mixed 32:1. i went and picked some up and mixed some for the weekend.
is this a half decent oil? he said its the same oil as they sell at the bike store but at a fraction of the cost.
also what do i use to safley clean my unifilter?
sorry but its been about 6 years since my last 2stroke bike
As long as the oil is TCW3 rated then it's fine. There are varying opinions on cleaning air filters, but I've never had a problem with soap and water.
what can i use to remove the oil in the filter? also what do you do with gas that you dont want to use in the bike because of age? if i put it in my vechile will it clog up the fuel injection system?
I use diesel fuel to clean the filter, make sure you get a good filter oil to re oil the filter with. I prefer the soaking oils you soak the filter with but you can also get spray ons as well. I wouldnt use the old fuel, just take it camping with you and use it as lighter fluid on your morning fires.
While you are at it you should change the gear case oil, sounds like the bike may be in need of some TLC. I use a pure synthetic Mobile 1, but there are many threads here that will give you opptions on that as well.
I use No-Toil filter oil and filter cleaner, the cleaner works great and is the only good way to get the filter oil off your hands totaly. I didn't know Castrol made a pre mix, there motor oil is great so their pre mix should be as long as it's TCW3 rated like supajdogg said. It beats paying 16 bucks for a quart of Maxima-castor 927.
Castrol is a good brand. Most on here agree that for normal pleasure use, run a full synthetic (not a blend) 2 stroke oil mixed at 40 to 1. Lots of good brands and everyone has their favorites. Many use Amsoil, Maxima(I use it) or others. Mobil 1 -2T is good and available at Auto Zone and other auto parts stores for value. Use the same one all time and mix it the same and then you can work on your jetting. Ride safe John
You can usually dispose of old gasoline by adding to the your waste oil. I bring all my waste oil to a repair shop that uses a waste oil furnace for heat. Those guys appreciate any oil that is thinner than normal. It helps balance out the 90W gear lube they put in there. If you live in a warm climate and you can't find a repair shop that burns the stuff, just bring ti to your oil recycler. It's no different than disposing of motor oil from a 4T that had a leaky float..and filled the base with gasoline.
Joe
thanks for the replys
turns out that the oil is not recommended for TCW so i will drain the tank out. should i put the gas into my truck or just put it into my oil barrel for recycling? gas is only a day old but not sure if i should be putting it in the truck with the oil mixed into it?
how is bel-ray S2? i have a sealed bottle of it that i never used before. otherwise i got a opened bottle of yamalube 2r that i have had for awhile.
BadgerMan
#9
KABOOM! :ohmy:
Every waste oil dump site I have used has a sign requesting that no solvents be mixed in with the oil.
Pour the old gasoline in your truck or use it in your lawn mower.
Mobil-1 2T is an excellent and clean burning synthetic two stroke oil. Most Autozone stores sell it for about $8.00 per quart. I mix it at 40:1 and use it in every two stroke engine I own.
You can run it through your lawn mower and it will do no harm, may smoke a little more when you first start it but it is better than wasting it. I use redline in my mix, Bel ray, and Yamalube are good as well.
BadgerMan said:
KABOOM! :ohmy:
i use a waste oil furnace and a little gas is actually GOOD for it. it helps clean up the spray nozzle and like was already said it thins out the oil in the tank to make it easier on the pump. doesn't explode, or even burn different.
Am I the only person on earth who cleans my air filter with dish soap and hot water? I always have since I was a kid, and never had a problem... :think:
It works well and is cheap, I have no problem using soap and water, but I have found diesel just does it a little faster with less work. Stinks and makes you stink too, but to all their own.
I use Bel-Ray Foam Filter Oil on my filter, and there is no way you can clean it with soap and water. The soap and water turns it into a blue goo that sticks to everything. Haven't tried proper filter cleaning fluid, but gasoline works like a bomb.
BadgerMan
#14
Notoil products are the best, IMO. I take the filter out and toss it in a bucket of water with some Notoil cleaner and let it soak for about an hour. Then, I wring it out and toss it in the washing machine (on a cold/gentle cycle) with some more cleaner and some old towels. The filters come out looking like new. Good stuff.
BTW, I have had filters fall apart in my hands before by cleaning them in hot water. It seems to melt the glue and they come apart at the seams.
Cleaning anything with gasoline is extremely dangerous. All it takes is a little electro-static discharge and you are in the middle of a big ball of flames.
