r1369ls is similar. Also honda 1369eka-2 which is cek-4. r 1369d-2 = cek 4.5. Carb Parts warehouse may have the cek. ddk-3 will be close up to 1/4 throttle then richer above by 1/2 clip compared to cek-4. The honda needles have a short transition taper from the straight section to the taper.
If you are interested in a spread sheet program which details the difference in needles see www.jdjetting.com
