scottgriz86
- Apr 30, 2005
- 3
- 0
Centering Crankshaft- Eric
Hi. I installed the crank in my KX125 after replacing main bearing/seals. After installing it, it was tough to turn so I hit the appropriate end and it freed it up, but the crank is still not centered. It has about .025" on the clutch side and somewhere around .05 on the flywheel side. I know there is some play between connecting rod and piston, so is this something I should be concerned about before assembling the rest of the engine? I've installed a few cranks before and a couple hits with a rubber mallet always popped them into center.
Thanks,
Scott
Thanks,
Scott
