May 9, 2007
9
Hi i just bought a cr125 and im wondering how much oil to put in when i change it theres not any in there at the moment so i was wondering if anyone could help with help much to put in there.
Thanx Mitch
slinger34
37
If you have a sight glass for the oil level should be half way up it.
(This is another post i found about a CR125)
it's probably around 650cc...
If you don't have a sight glass, there might be an odd looking bolt on the face of the clutch cover. If so, that is the level.. remove the bolt, fill until oil starts coming out. Replace that bolt, you are good to go. Also, try looking on the engine near the oil fill hole, it may just say how much oil to use.
FRESH VIDEO
