There's one on Egay right now starting at $17. Is there any similarity between this carb and the ones on other Yamaha scooters? It may do you some good to talk to the dealer and see what other models used the same carb. Expand your possible donor pool.
If you will measure both ends I might be able to help you out with a non-stock replacement since it appears to be a pretty standard carb for horizontal singles.
