MarKGftAV
17
i just redid my clutch plates and now there is absolutely no resistance in the clutch at all and the clutch isnt engaging. i tried fooling around with the cable setup but no luck. any ideas?
j.lawson
78
springs, pressure plate, push rod, lifter lever thing? did you put it in the way you took it out? pop your clutch cover off and see whats going on.
Trashrider
170
Consult your service manual for the exact number of plates your bike requires. It is possible you are missing two.
Mark
IndyMX
Crash Test Dummy
5,548
Amo, IN
76GMC1500 said:
I think you left a part out. Most likely, you forgot either the pushrod, ball bearing, or lifter thingy at the end.
I hate to rain on your parade, but if he left out any of that, the clutch would engage just fine.. It wouldn't release worth a damn though.
I'm going with Trashrider on this one...
I have a new clutch kit for a CR125, says its for a 95 to 2001 or some such.. But it's two plates short of fitting my bike.
76GMC1500
Uhhh...
A more well thought out idea, did you remember to put the pressure plate springs in? If they weren't there, that would cause the clutch to not engage and feel like it was all freeplay. Leaving plates out might cause the clutch to not engage, but you would still have resistance from the springs as you pulled the lever.
MarKGftAV
17
i have everything that i need but the clutch rod is too short to push the cover or basket out to disengage the clutch. ive even tried putting in my old plates and no luck. according to the manual i am not missing any parts either.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Take some pictures of everything as it is.. Let us see, someone should be able to find the problem.. Oh, when you take pics, make sure they're in focus.. It's just easier that way..
Even if you are not super close, focus is more important.
MarKGftAV
17
pictures:
<img src=http://netmail.verizon.net/webmail/servlet/HttpNimletDriver?nimlet=DownloadAttachmentNimlet&fileName=0726071454a.jpg&folderName=INBOX&messageID=1915&partIndex=1&disposition=inline>
The clutch rod shown here is not meeting up with the clutch cover (the round thing that covers the plates) (not the engine cover).
IndyMX
Crash Test Dummy
5,548
Amo, IN
MarKGftAV said:
pictures:
That really didn't work out for ya... Try posting to one of the free image websites..
j.lawson
78
so the lifter, thing that looks like bolt with washers is not pushing your pressure plate to dis-engage the clutch then?
you installed the springs correctly....does your model have the little ball bearing that sits inbetween the lifter and the push rod? did you install that if so?
MarKGftAV
17
It was 8 months ago that this bike was taken apart. If i had one it is somewhere in my garage. im going to go look for it right now. what does it look like?
j.lawson
78
its just a tiny metal ball, like out of a ball bearing. Its about the diameter of the push rod, it sits inside the lifter and the push rod goes in behind it. but, some bikes and models didnt have them, i think. every bike iv worked on has though. good luck.
MarKGftAV
17
where can i buy one of these?
j.lawson
78
from looking at a oem schematic your bike (2004 cr 250r) does not have that little ball.
http://www.bikebandit.com/partsbandit/showschematic.asp?dept_id=1134075
^^this ^^ is the link to that schematic, make sure every part is there and assembled in that order on your bike with the right amount of clutch plates.
from the schematic it looks like there should be a bearing(#22), a washer (#23), and a clip (#1) on the end of the lifter, it may be there but the pic is outta focus so I cant tell?
MarKGftAV
17
shucks. i dont have any of that. its long gone by now.
j.lawson
78
lol, well go to bikebandit.com and enter click honda, make model blah blah :blah: , and figure out what you need and go from there bro. goodluck :cool:
Where is your pressure plate? It is not in the picture.
