yankeefan4life72
- Sep 15, 2004
- 195
- 0
today i pulled the 98 kx 100 motor out and put it in a 92 kx 80 frame......fit like a glove.I went to kick it over and to my surprise it started on the 3rd kick :laugh: the motor sounded real good so i began to put the sprocket and chain on.after i did i took it for a ride and when i started to go it is acting like the clutches are slipping....the more throttle i give it the worse it gets.so i think.....i hope it is just the clutch.i let it sit for about 3 hours when i went to ride again .....i put it in 1st gear let the clutch out and the bike didnt move tried 2nd and still nothing.so i am hoping it is just the clutch right???also when i did ride it there was an extreme amount of oil coming out of the silencer.....i am not talking about spooge i mean actual oil dripping all over the swingarm.when i pulled the pipe off the 100 it was full of gas....it had been sitting on its side for awhile so i thought it was just burning out the oil that was left in the pipe.took off the silencer checked in the pipe for oil residue and found none...took the silencer apart and it is loaded with oil. will try to re-pack the silencer and see if it stops.has anyone ever used tusk clutches??i can get a whole kit for $35.00 online any feedback please this bike is for a kid so i am not trying to spend a fortune on it.also when i pin the throttle it acts like it is sputtering.Could that be the reeds or a plug??thanks alot
