I used Mobil 1 ATF. With that, an Enduro Engineering clutch line and EE easy pull lever you will feel like you died and went to heaven. It is cream puff smooth and easy.
ATF is a recommended replacement (Enduro Engineering) Always use an unopened bottle to prevent contamination. Thoroughly flush/bleed to remove all traces of the Magura Royal blood. (About six ounces to get it all out.)
