clutch pull?
I'm looking for the easiest clutch pull out there. I thought i heard something about teflon coated cables but i'm not sure. If there is such a thing, where can it be found? Any other hints for easy clutch pull for a 03 CR 250?
Replace your cable with a Motion Pro T2 cable, and keep it lubed. If you are still not satisfied, get a Moose Easy pull clutch system thingy, if you still want and easier pull go get a hydraulic clutch, you can pull it in all the way with your pinky.
KaTooMer
Subscriber
Is the hydraulic clutch slave unit vulnerable to trail junk? (tree branches, rocks and stuff). Seems like there's not a lot of protection in that area. Would live to try one, though.
Where can i get a good buy on a hydraulic clutch? Anywhere online? And what brand is the best?
