Garrettc
Hello I recently got a MX 175 from my grandpa and I need some help! It has a seized engine. I put some Marvel Mystery Oil through the spark plug hole. It has been sitting for about a day. Anyone have any other suggestions! Also the clutch won’t engage. I pull it in and nothing. My grandpa said the clutch plates are probably stuck together from sitting for to long. I don’t exactly know how to fix this. I just need a little bit of extra help!! Thanks!!!
Mully
Moderator / SuperPowers
Jun 9, 1999
4,234
114
Unfortunately there is no magic additive that will fix these problems. An MX 175 sounds like an older late 70's early 80's type of dirt bike. A good starting point, if you are experienced mechanic, would be to purchase the service manual. From there you would be able to rebuild the engine, replace / service the clutch, and clean the carb. There is most likely many other things that will need your attention before you will be able to ride the bike.
Mully
