Coil , kill switch not working, broken wire
msomso
38
The little wire from the coil to ground on a 1999 KTM Pro JR is broken right were it comes out of the coil.
The coil still works, just won't shut off.
How can this wire be put back into the coil?
Drill ?
Or, is it not repairable.
David Trustrum
1,396
Never seen one but assuming you have a plastic coil & the wire has broken off flush with the surface.
You can follow the wire in with a soldering iron until you have enough to solder to, then epoxy the join & cable-tie the wire so if it gets pulled on it won’t break. Scary part is you don’t want to hit any other wires so aim away from the other wire, maybe toward the outside of the case.
There will be residue on the wire so a grunty flux will help you tin it.
Clean the soldering iron well as this residue ain’t the best for it.
